Plant SCADA TabStyle navigation menu bar highlight
Hello everyone,
I am currently working on a project in Plant SCADA using the TabStyle template. I’ve run into a synchronization issue with the navigation menu highlighting:
  • Current Behavior: When I navigate using the top Menu Bar, the selected button stays highlighted (dark), which is correct.
  • The Problem: If I change the page using a button located directly on a graphic page (e.g., a "Back" button or a custom link), the Navigation Bar does not update. The highlight remains on the previous menu item, leading to a mismatch between the current page and the selected tab.
Question: How can I force the TabStyle menu to refresh its state so that the highlighting matches the current page name? Is there a specific Cicode function I should call to synchronize the menu selection?
Environment:
  • Software: AVEVA Plant SCADA (Citect)
  • Project Template: TabStyle / TabStyle_Include
Thank you in advance for your help!
Best regards, AVEVA User
Parents
  • I haven't used these templates much, but being an include project, all the source code is visible for inspection. Tab_Style_Include. Open in Cicode Editor.
    It appears when a user clicks on the page buttons at the top that it calls the public function TabMenu_Button_select(buttonID) in tabmenu.ci. This function will trigger the button to display the target page and highlight the button. This function calls an internal function (to do the highlighting: _Tabmenu_PreSelectedItemSet.
    I would suggest that your buttons on your pages should call TabMenu_Button_Select(buttonID) and then everything should work automatically.
Reply
Children
No Data
