Good evening,
This may be a lack of understanding how PlantSCADA works under the hood.
I need to log an equipment rearm reason on a PlantSCADA 2023 project, I'm slowly learning how to use the SQL functions with Cicode, but part is fine.
My doubt is how will the PlantSCADA clients also access the SQL DB?
Currently I'm using the OBDC method to provide the DSN, and it works on the server.
So far I'm testing on a VM, so I dont have a test client to test if just using the DSN in the server will work, or if I need to somehow also get the clients to connect to the SQL Server.
Best regards.
