Drop-down menu for MV point
Hello, there is an MV point with several states (state-1, state-2, state-3, etc.). Can someone tell me
How to make a drop-down menu to select these states?
A menu of the kind shown in the picture (taken from another SCADA, where this element is present directly on the toolbar)
  • Nick said:
    Most flexible? You mean the most outdated. You clearly haven't used Ignition! Easy to work with, and it's incredbily flexible
    It was sarcasm ))
    How do you do export trends to text file in Citect? in Ignition? In WinCC ?
    How do you do archive of alarms in Citect ? in Ignition? In WinCC ?
    In my threads here about the questions you can see answers like "use cicode.... external data bases ... citect is very flexible"
  • Bas said:
    You can also use just a Citect Genie in combination with the new Maps functionality. I took a genie from the TagDebug Example of Bradley and modified it for use directly on a page. It then look like this:
    So no need for ActiveX solutions
    Hello. Can you show the code for for such a result?
  • Viktor said:
    Bas
    You can open the  tag.ci from Inlude project
  • The function TagDebug uses Citect Forms ..... and LisBox, ComboBox etc. from Citect forms .... it looks like non ActiveX .... for example LoginForm made on Citect Forms
