May I ask how do I put in the start time, end time, frequency filters?
  • (Missing Content)​  Thanks, it was a problem on my end, didn't realize I was passing milliseconds too. One more thing, on DST (11/5/23) it's only passing the 24 hours when I'm expecting 25 (I validated with PI Data Link, which has 25 hours). Trying to figure out if that's a me problem or an API problem. My guess is the API will populate the JSON object with the 01:xx timestamps, and then repopulate them with the newest values because it would be a duplicate key:value pair.
  • Sure, I'm expecting to see operating hour 01 to be repeated. Please see the calls and responses below:
    PI Data Link Query:
    =PICompDat("PI_TAG","11/01/2023","12/01/2023",1,"","inside")
    PI Data Link Response Snippet:
    05-Nov-23 00:00:00	28.2246418
    05-Nov-23 00:10:00	-144.0289612
    05-Nov-23 00:20:00	19.67341805
    05-Nov-23 00:30:00	-49.99599457
    05-Nov-23 00:40:00	102.5537949
    05-Nov-23 00:50:00	109.2017746
    05-Nov-23 01:00:00	92.88484192
    05-Nov-23 01:10:00	137.7048187
    05-Nov-23 01:20:00	147.2772827
    05-Nov-23 01:30:00	61.2579155
    05-Nov-23 01:40:00	15.768363
    05-Nov-23 01:50:00	119.312355
    05-Nov-23 01:00:00	73.52394104
    05-Nov-23 01:10:00	107.8926926
    05-Nov-23 01:20:00	137.6197815
    05-Nov-23 01:30:00	90.47686768
    05-Nov-23 01:40:00	14.6219759
    05-Nov-23 01:50:00	66.63463593
    05-Nov-23 02:00:00	29.79430008
    Python call:
    response = session.get(f"{base_url}streams/{web_id}/recorded", params=params)
    params = {
        "startTime": start_time, (passed as 11/01/2023 00:00:00.00
        "endTime": end_time, (passed as 12/01/2023 00:00:00.00
        "maxCount": '50000',
        "timezone": 'UTC-08',
        "includeFilteredValues": 'false',
    JSON Response Snippet:
    {'Timestamp': '2023-11-05T08:00:00Z', 'Value': 92.88484, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T08:10:00Z', 'Value': 137.704819, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T08:20:00Z', 'Value': 147.277283, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T08:30:00Z', 'Value': 61.2579155, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T08:40:00Z', 'Value': 15.768363, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T08:50:00Z', 'Value': 119.312355, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:00:00Z', 'Value': 73.52394, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:10:00Z', 'Value': 107.892693, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:20:00Z', 'Value': 137.619781, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:30:00Z', 'Value': 90.47687, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:40:00Z', 'Value': 14.6219759, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T09:50:00Z', 'Value': 66.6346359, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
    {'Timestamp': '2023-11-05T10:00:00Z', 'Value': 29.7943, 'UnitsAbbreviation': '', 'Good': True, 'Questionable': False, 'Substituted': False, 'Annotated': False},
  • (Missing Content)​ I'm doing two things for the time zone, I'm passing the UTC-08 timezone param (which doesn't seem to work as expected as it still reports back UTC) and then I have a cleaning function in my code (which could very well be the culprit). I see what you're talking about though... is my timezone param accurate if I'm requesting PST? Maybe it has to be dynamic based on time of year?
  • Hi ​,
    I'm not sure if I understood you correctly. With recorded values, you can only use outside, inside or Interpolate. Whether you get a value at the start/endtime or not can be changed due to the boundary parameter. But if there is no value at the boundary and inside param is used, then you won't get a value there. With boundaryValue=interpolated, you'll always have 1 value at each boundary. Does it sort of answer your question?
    May I know the query/requesting URL? and possibly the returned response? Some example would be great to understand you better!
    Thank you for the information. I think I can see the values in the repeated hours. There are the same values in:
    • 1AM#1: DataLink result Line 7 <-> PIWebAPI result Line 1
    • 1AM#2: DataLink result Line 13 <-> PIWebAPI result Line 7
    The PIDL results are printing values in client time zone (thus overlapping time range)
    PIWebAPI reports back with a UTC Time without any DST (thus it's not overlapping). When you translate the time into the local time, I think you'd see the result as the same?
    PIWebAPI will always report back with UTC timezone regardless of the client time zone.
    Please find this page of the user guide, Time Zone (Core Services) (aveva.com) If a daylight savings time boundary falls within the time zone offset start time or end time and there is an interval specified, then the time zone parameter will be honored.
    It would seem that you are requesting hard-coded UTC-8. I suspect this would actually be changing though depending on DST. Perhaps it may be better to write the timezone as 'Pacific Standard Time'.
