I was using Query Client to view the events; I could see the normal properties, but I was not able to see the custom properties added using my code. I have attached the code and query I have used to add and retrieve the events. Does that query require mor
// Create the event
HistorianEvent historianEvent = new HistorianEvent
ID = Guid.NewGuid(),
EventTime = DateTime.Now,
ReceivedTime = DateTime.Now,
//Source_Name = "MyObject",
Type = "TestEventType",
// Add custom properties
if (!historianEvent.AddProperty("RandomName", "This is a custom event message", out error))
Console.WriteLine("Failed to add 'Message' property: " + error?.ErrorDescription);
if (!historianEvent.AddProperty("Severity", "high", out error))
Console.WriteLine("Failed to add 'Severity' property: " + error?.ErrorDescription);
if (!historianEvent.AddProperty("IsAlarm", false, out error))
General
Console.WriteLine("Failed to add 'IsAlarm' property: " + error?.ErrorDescription);
// Add the event to the Historian
if (!historianProcessAndEvent.AddStreamedValue(historianEvent, out error))
Console.WriteLine("Failed to add event: " + error?.ErrorDescription);
else
Console.WriteLine("Event added successfully.");
Above is the code I have used to  create some custom properties for the events and add the events.
I am using this query
SELECT * FROM Events WHERE EventTime between '2025-07-31 0:00' and '2025-08-01 0:00'
to see the events added in Aveva Historian Query tool. I can see these events added in the query results. But the table does not show the custom properties added using my code (For instance the property RandomName).
How will I be able to see the custom  properties that I set using the Query.
I can retrieve back the value for RandomName using the code provided in SDK but I need to get the query to view it in Aveva Query Tool
