Run OPC UA Wrapper as a service
Hello,
I am using the OPC UA Wrapper to get connections from an external OPC UA Client. How the OPC UA Wrapper can be configured to start as a service (or automatic startup) when the host computer starts?
Thanks,
Arian
  • Hello Arian,
    Did you install OFS UA wrapper from version 3.60?
    I assume that OFS is also running as a service!
    Open an elevated command prompt.
    Type: “CD C:\Program Files (x86)\Schneider Electric\OFS\OPCUA\UAWrapper\” Enter
    Type: “Opc.Ua.ComServerWrapper.exe /install” Enter.
    Check the Windows Task manger on OPC UA Executable and Wait a While.
    The service will be installed. Check if the service is configured as automatic start up
    Thijs-Jan
