Hello,
I have an issue with real variable tags in CirectSCADA 7.40 SP2. A real variable is declared in the PLC at address DDT1220, I create the same name variable tag, pointing to DT1220 (CitectSCADA does not accept the format DDT...) and select the type as Real, and each time it compiles, it returns the error "Bad raw data type" on that variable. If I set the type as Long, it compiles without any error, what am I missing?
Thanks.
