Writing Genie Form Files
When creating a form, the following format is used:
FORM "<genie>"[,"<form title>"];
<field number>:"<field name>", <field size> [,readonly/readwrite[, "<list form>", "<list field>"[,"<list filter>"]]]; ...
NORMAL
"<prompt> {<field number> }
Can anyone write all possible kinds "<list form>" and <list field>?
  • Not sure, but I suggest you take a look at the example project as I remember seeing them used in that
  • According to TN5854 any database (dbf) referenced in citect.frm can be a list form and the list field is a column of the dbf used for the list form.
  • It looks like you copied your message title and genie format text from TN3979/Q1764. That article also defines listform and listfield, like Erik said:
    "Any of the forms defined in CITECT.FRM can be used as a 'list form'. If a form from CITECT.FRM is used as 'list form' then 'list field' can be any of the fields from the forms record definition."
    That article also has a special case for ActiveX objects that I had copied from the Example project into the article years ago (I'm not sure if it's still used in the Example project):
    ! This form uses special 'list form', 'list field', and 'list filter' names
    ! to create a drop-down list of ActiveX object names
    ! This feature is available in Citect 5.20 and later
    FORM "Insert_Object", "Genie - Insert Object";
    1: "GUID", 128, readwrite, "<<", "ListActiveXControls","0";
