Actually installed CitectSCADA Ver.8.00 with floating licenses.
When installing CitectSCADA Ver.8.10 what happens to the actual floating licenses?
Should the floating licenses be uninstalled before to start the installation of Ver.8.10?
Thank you for comments
Hi Adriano ,
V8.00 comes with FLM version 1.9.4.0, when you uninstall Citect, then install V8.10, it will try to upgrade FLM to v2.1.0.0. The activated licenses will remain intact. You just need to make sure that the softkey license is valid to run that newer version of Citect you just installed.
