I have this issue with Citect 2016, I restarted the server standby. it stays on the "starting" status with this message "waiting for alarm database initialization" on the alarm service. thank you per advance for your help.
Hello.
I have the same issue with Citect 2018R2, running as a service. In my case the secondary Alarm server is running well and the primary is always starting with the same message "waiting for alarm database initialization".
I found this: https://www.se.com/in/en/faqs/FA235872/ My topology is ok, but I have two IP adresses in each AlarmServer (and just one is defined in topology - network adresses). I already tried with or without DSN name configured in topology - computers configuration and the result is the same.
Any hint?
I found in ...\logs\tracelog.Alarm.??MyProject??.ALR_SRV_1 with:
2021-06-08 12:53:32.870 Error Transport TcpipTransport::EndConnect() [CLIENT 0.0.0.0:62964 --> 172.????:2082 #1] SocketException: No connection could be made because the target machine actively refused it 172.????:2082
2021-06-08 12:53:59.342 Error Transport TcpipTransport::EndConnect() [CLIENT 0.0.0.0:63055 --> 172.????:2082 #2] SocketException: No connection could be made because the target machine actively refused it 172.????:2082
2021-06-08 12:54:04.343 Error Transport TcpipTransport::EndConnect() [CLIENT 0.0.0.0:63070 --> 172.????:2082 #2] SocketException: No connection could be made because the target machine actively refused it 172.????:2082
it appears to be firewall related, but citect runtime and citect runtime 64 are in the allowed processes.
When you say two IP addresses in each alarm server, are there two network cards on the same subnet? It might be worth temporarily disabling one network card and just run the one IP address configured in the project. The DSN name is really required when running with encryption enabled.
Is this machine you are testing on a VM? I have heard of another tester internally having trouble where his client process could never connect to local processes, which turned out to be an issue with the VM and host network config.
Try run the Example project and see if it runs and connections work. Then if that works, run your project and check using netstat -a that the processes are listening on those expected ports defined in the project
Olivier I believe while the DNS name is required when you define the Computer, for the Network, it is better to use one IP address for the moment as per other issues that may be raised.
Nuno Ventura let continue with support.
The servers have two network cards, but with different subnets (one for field, other for office).
I disabled encryption (still running as service).
This is in production, not test, but is virtualized on ESXi,
One of the servers had Windows Firewall active for public network, I turn it off and the alarm servers finish syncro and are working ok.
I put the DSN names again and it's still working.
Next step: reactivate encryption.
After next step: fight with windows firewall to discover why it doesn't respect the exception rules. Or why the rules are wrong.
Very strange! Do share your findings of what was blocking those ports. I find Windows Firewall has been reliable in the past, especially when you let Citect installer add exceptions.
Good morning
Encryption on again, all ok.
netstat -a -b shows the established connections between the two PCs in the ports:
2080 (7 connections out; 7 in) Citect.exe
2082 (6 connections out; 6 in) Citect32.exe
2084 (7 connections out; 6 in) Citect32.exe
2085 (7 connections out; 7 in) Citect32.exe
5482 (2 connections out; 3 in) Citect.exe
There are other citect established out connections with PLCs and MySQL
Checking firewall rules (with command "netsh advFirewall Firewall show rule name=all"), in both PCs are the same, there are 4 rules, all for allow, any IP, any port, direction "in" and profile "Private" , 2 for UDP and 2 for TCP and each one for Citect SCADA Runtime or Citect SCADA runtime (x64).
Hello Everyone!
I'm working with Citect SCADA 8.20 update 15 on Windows Server 2019 Standard.
When trying to run Citect in server mode (redundant), the Alarm Process fails to run, generating the following message.
"Could not initialize alarm database. This may indicate your project has incorrect alarm server configuration"
Thank you per advance for your help.
Hi Osmar Oliveira,
You might have better chances of getting help if you create a new post. This one is more than 4 years old and is about a different topic.
For your problem you could delete and rebuild the alarm database. By doing this you will lose all alarm history though.
The procedure is:
1. Stop Plant SCADA runtime. At least the Alarm Server(s), but I always do a full shutdown.
2. In Windows (File Explorer) go to the Plant SCADA Data folder.
3. In the Data folder you will see a folder with the same name as your main project. This is the alarm database.
4. Remove all files and sub-folders in the alarm database folder.
5. Restart Plant SCADA. It will rebuild the database. You can see the progress in the Runtime Manager.
