Hello all,
How can i change the language in the process analyst? I have been seeing the help but when i find the Resource.dll i cant find it?
Best Regard,
Merry Christmas
Hello all,
Best Regard,
Merry Christmas
Hi Sebastian,
You can Process Explorer to verify that the language DLL loaded:
Process Explorer - Sysinternals | Microsoft Learn
I and one of our testers confirmed we can switch languages on Windows 11 with the Process Analyst.
What we did find, is that we forgot to add the [ProcessAnalyst] section to the profiles included with the Example and ExampleSA projects.
So make sure you do this: Using Plant SCADA to Switch the Process Analyst Language
OK, that suggests the [ProcessAnalyst] section mapping for Polish wasn't present, as that is what controls the loading.
Are you able to run the Example project on those machines just confirm other languages work like French? Just make sure the citect.ini has the [ProcessAnalyst] section in it with the french mapping.
I test with Example project to switch to FR and it is working:
with PL not on this machine with my project:
i also attached screenshot with properties my resources file:
there is no Aveva digital signature, but I don't know if it matters, if it works on other machines
This is my resources_pl file:
