For single plant with multiple clusters, the active alarms equipment tree appears per following image,; each cluster has its own root node.
However, since the equipment is actually common to both clusters, it is preferable that the equipment tree appears per the following image, with a single root node and the alarms from both clusters combined into the equipment nodes. Is it possible to have the equipment tree appear in this way? Using CitectSCADA 2018R2.
