Further to an earlier post about passing a cicode global variable argument into a function that is called by a super genie graphic window, I have got all the code working properly thanks to the wonderful help from this community!
It seems now the problem I have is that the function is not always called when the supergenie window is called. I have created a variable on the supergenie window that tells me if the code has been executed and in some cases it has not.
The variable that is set true by the code, so I then created a 'while do' loop to try and execute the code continuously until the variable is set true.
I think the problem is that for some reason the page event doesn't always run when the page (supergenie) is called and leaves check variable false, indicating the code has not been executed.
I have read all the help documentation and believe everything is correct. The documentation notes that there can be issues when using the 'on page entry' event so I have used 'on page shown event'. I note that the 'while page shown' event does not at work at all and not sure why this is.
Any help appreciated
Regards
Daryl
