Can Cicode read data from a CSV file ? if so has anyone done it and are willing to share some sample code.
ideally it would be better if the file was .dbf
Hi Alan
Unfortunately, there is no such a Cicode funtion for reading a CSV file. It looks like you have to code it yourself. Here is a guideline
Good luck and hope this would help.
There are several things to consider when reading from a CSV. The simplest is if every line is less than 255 characters so it can be read as one string. Then you just need to search for commas in that string to find each field.
If the lines may be longer than 255 characters, then you need to read multiple blocks of 255 characters, searching each time for commas. If a block has a comma near the end then you need to add the remaining text to the first field of the next block.
If the CSV has text (not just numbers) then it is common for the text to have quotes around it. That makes your searches more complicated since you have to ignore commas inside of a text string.
Here's a Cicode function that makes it easier to get the fields from a CSV line. It does not handle quotes, though.
//Get a field value (text) from a string, where the string consists of a number of fields separated by
//a field separation character such as a comma
//Example:
// sText = "ab?cde?fghi?j";
// sField = StrGetField(sText,3,"?");
//In this case sField = "fghi"
//Field numbers start at 1.
STRING FUNCTION StrGetField(STRING sText, INT iField, STRING sFieldSeparator = ",")
INT iOffset = 0;
INT iPos = 0;
INT iIndex = 1;
ErrSet(1);
WHILE (sText <> "") AND (iIndex <= iField) DO
iPos = StrSearch(iOffset, sText, sFieldSeparator);
IF (iPos < 0) THEN
iPos = StrLength(sText);
END
IF (iField = iIndex) THEN
IF iPos > iOffset THEN
RETURN(StrMid(sText, iOffset, iPos-iOffset));
ELSE
RETURN "";
END
ELSE
iIndex = iIndex + 1;
iOffset = iPos + 1 ;
END
END
ErrSet(0);
RETURN("");
END
You could also check out the Trend Import CSV tool in the Toolbox. It reads in a CSV file for trend data. The GetLine and Split functions process each line of the CSV. It demonstrates how to handle lines longer than 255 chars. It also uses the StrSearch and StrMid functions directly, instead of using StrGetField() for better performance.
Hi Eric and Jacky,
Many thanks for the prompt responses, very much appreciated.
Regards
Alan
