Can Plant Scada support FTP Functionality ?
Depends on version.
Following function was removed in Plant SCADA 2023:
FTP Functions
FTPClose
FTPFileCopy
FTPFileFind
Since it is no longer built in, you can use a 3rd party tool, or the Windows FTP command line tool. Here's a script I wrote years ago to do an FTP upload using the command line. It's kind of a pain because you have to write a FTP command script to a text file, then run FTP.exe and tell it to run the script, then read back the log file it creates to tell if it was successful.
// Function: FtpUpload
// Description: Uploads a file to an FTP server
// Revision: 1.00 4/29/04 Eric Black Original
// Arguments: sURL URL of the FTP server (e.g. ftp.myserver.com or localhost or 192.168.1.1)
// sUser FTP server login user name
// sPassword FTP server login password
// sLocalFile Path and filename to upload (can use path substitution)
// sRemotePath FTP server folder to upload to (e.g. Reports\Current). Default is "." for the default folder
// Return Value: 0 if successful, otherwise a Citect error code is returned
// Notes: 1. This is a blocking function
// 2. If the upload fails, check [Data]:FtpLog.txt for errors before calling FTPUpload again
// or the log will be overwritten.
// 3. If FtpUpload returns 1340 (timeout), but the upload eventually finishes successfully you may need to increase
// the UPLOAD_TIMEOUT_SEC value (default is 5min)
// 4. If this function is called from multiple threads, they will get queued up and only 1 will
// run at a time.
// 5. The sRemotePath may be case sensitive. It may also require either '/' or '\' to separate folder names. If
// the path is invalid the file will upload to the default folder.
// 6. The Citect IDC FTP Server does not support receiving files at this time (Citect 5.50)
// Example Command: FTPUpload("ftp.widgets.com", "scadauser", "scadapwd", "[data]:dailyreport.htm", "SCADA/Reports");
INT
FUNCTION
FtpUpload(STRING sURL, STRING sUser, STRING sPassword, STRING sLocalFile, STRING sRemotePath = ".")
// Local Constants
STRING SCRIPT_FILE = "[Data]:FtpScript.txt";
STRING LOG_FILE = "[Data]:FtpLog.txt";
STRING SUCCESS_RESULT_CODE = "226";
INT UPLOAD_TIMEOUT_SEC = 300;
// Local variables
INT hScriptFile = -1;
INT hLogFile = -1;
INT hFTPWindow = -1;
INT iUploadStartTime;
STRING sText;
STRING sComSpec;
ErrSet(1);
IF NOT FileExist(sLocalFile) THEN
RETURN 261; // File does not exist
END
sComSpec = GetEnv("ComSpec"); // Get path & filename of DOS command interpreter
EnterCriticalSection("FTPUpload");
// Create a new FTP script file with the specified settings
FileDelete(SCRIPT_FILE);
hScriptFile = FileOpen(SCRIPT_FILE, "a");
IF hScriptFile = -1 THEN
LeaveCriticalSection("FTPUpload");
RETURN 264; // Cannot write to script file
END
FileWriteLn(hScriptFile, "open " + sURL);
FileWriteLn(hScriptFile, sUser);
FileWriteLn(hScriptFile, sPassword);
FileWriteLn(hScriptFile, "binary");
FileWriteLn(hScriptFile, "cd " + sRemotePath);
FileWriteLn(hScriptFile, "put ^"" + PathToStr(sLocalFile) + "^"");
FileWriteLn(hScriptFile, "bye");
FileClose(hScriptFile);
FileDelete(LOG_FILE);
// Run the script by executing ftp.exe -s:"<script file>" > "<log file>"
// The '>' sign redirects the output from the screen to the log file
// "s are necessary in case there are spaces in the paths/filenames
Exec(sComSpec + " /c ftp.exe -s:^"" + PathToStr(SCRIPT_FILE) + "^" > ^"" + PathToStr(LOG_FILE) + "^"", 6);
iUploadStartTime = TimeCurrent();
SleepMS(500);
// Hide the command window
hFTPWindow = WndFind(sComSpec); // NT/2000/XP window title
IF hFTPWindow = 0 THEN
hFTPWindow = WndFind("FTP"); // Windows 98 window title
END
IF hFTPWindow > 0 THEN
WndShow(hFTPWindow, 0); // Hide the FTP command window
END
// Watch for upload to complete, fail, or time out
WHILE TRUE DO
IF FileExist(LOG_FILE) THEN
IF hLogFile = -1 THEN
hLogFile = FileOpen(LOG_FILE, "r");
RETURN 262; // Cannot open log file
END
END
FileSeek(hLogFile, 0);
WHILE NOT FileEOF(hLogFile) DO
sText = FileReadLn(hLogFile);
IF StrLeft(sText, StrLength(SUCCESS_RESULT_CODE)) = SUCCESS_RESULT_CODE THEN
FileClose(hLogFile);
RETURN 0; // Success!
ELSE
IF StrRight(sText, 3) = "bye" THEN
RETURN 264; // Cannot write to FTP server. Check ftp log
END
END
END
END
IF TimeCurrent() - iUploadStartTime > UPLOAD_TIMEOUT_SEC THEN
RETURN 1340; // Timeout. Upload may complete eventually
END
Sleep(1);
END
END
