Hi Guys,
I am trying to utilise custom equipment parameters on V8.2
The parameter is being created but the default value does not pass through to my equipment and i need to manually enter it.
See images
Hi Guys,
See images
How did you create those equipment instances, from Equipment Editor or from Bulk Editing Tool - "Project DBF AddIn"? I briefly tested the default parameters with Equipment Editor in v8.20 and the default parameters are populated.
Hey Jacky Lang
I entered these manually through the Equipment Editor.
I added the individual equipment under System Model/ Equipment.
Didnt Import/Export anything.
If you create an equipment instance outside of Equipment Editor, make sure that the name of "Type" in Equipment Model must be identical defined in Equipment Type because the type name is case sensitive. Take a look at the editor log file,
where you can see the errors for those missing parameters when the model is loaded into Equipment Editor.
Hope this would help.
Regards,
Jacky
Hi Travis Bailey ,
Any update on this issue?
