Hey guys!
So, we had an issue (long story) at a customer and long story short, we need to reinstall the PCS services to get things back to normal. Following the user guide, it tells you WHAT msi to run, and that's great. However, when you get to the installer portion, it gives you two options; the PCS Runtime, and the PCS Service Repositories, which is de-selected by default.
My question is - when should you install just the runtime vs both?
Thanks much
-Phil
