A customer recently asked about filtering on multiple values of an attribute in AFSearch. This is easily addressed using the IN search operator in a query string, or the equivalent AFSearchToken constructor expecting an array of values. There is one major caveat: the IN operator is not allowed for floating point types such as Single or Double, since binary floating point values are considered approximations instead of exact numbers.
There are a few tips to get developers pointed in the right direction. First of all, values within the IN operator are delimited by semi-colons. If you (like me) accidentally use a comma-delimited list, then you will receive an odd error about missing a closing parenthesis. Then if you carefully inspect the query string, then you (like me) will start pulling your hair out because you don’t see a missing closing parenthesis! Hopefully you may benefit from my pain by quickly switching your delimiter to be a semi-colon.
Another tip is that while blanks are allowed within the IN operator - or more specifically around the delimiters - any values that contain embedded blanks must be wrapped in quotes (single or double quotes). Consider this list of cities:
- London
- Paris
- San Francisco
Obviously, San Francisco needs to be wrapped in quotes due to the blank inside the name. If the attribute path is “|City”, then you could have this C# filter in your query string:
string uglyQuery = "|City:IN(London; Paris; \"San Francisco\")";
Though ... that is a wee bit ugly. Besides being ugly, it also might be confusing to someone using a different language, for instance, VB.NET. A couple of weeks ago, I taught a class where a VB coder thought the unsightly \" were delimiters for AFSearch. I explained to him that it's how C# escapes double quotes. This can look much easier on the eyes if you just use single quotes:
string prettyQuery = "|City:IN(London; Paris; 'San Francisco')";
And it avoids any needless confusion that \" is an AFSearch delimiter.
This is all fine-and-dandy, but how often do you hard-code values? It does make the example simple and straight-forward, but what if the list of items you wish to filter upon are in a list or array? Let’s look at some code that helps us out. After all, this is a PI Developers Club, which demands for code. Strictly speaking, all we need for the collection of values is that they be in an enumerable collection. Your source collection doesn’t have to be strings, but keep in mind that eventually we will need to pass a string to the AFSearch query, or if we use the AFSearchToken, then we must actually pass an array of strings.
For our cities example, it makes sense that the city names are strings. Let’s not take the easy way out and make it an array of strings. Instead we will use a list so that we can see what we must do differently to make it all work together:
List<string> cities = new List<string>() { "London", "Paris", "San Francisco" };
A tiny bit of code is needed to put that inside a query string:
// A little LINQ to wrap single quotes around each city, and separate them with "; "
string delimitedCities = string.Join("; ", cities.Select(x => $"'{x}'"));
// An Interpolated String to substitute the delimitedCities.
string query = $"|City:IN({delimitedCities})";
This resulting value in query would be:
"|City:IN('London'; 'Paris'; 'San Francisco')"
Or if you prefer working with search tokens, this would be the equivalent:
// Tip: here you must pass a string array, so we must ToArray() on the cities list. AFSearchToken token = new AFSearchToken(AFSearchFilter.Value, AFSearchOperator.In, cities.ToArray(), "|City");
If we had defined cities to be a string array, we would not need the ToArray(), but then this example would be boring and less educational.
What if our enumerable collection isn’t a bunch of strings? Let’s say we have a bunch of GUID ’s. (Exactly how you got these GUID's is an interesting question not addressed here ; suffice to say this example takes a collection of things that aren't strings and converts them to one that is.) There would now be an extra step needed where we must convert to string. Once we have a collection of strings we can then implement code similar to the previous examples. Let’s imagine we have something like this:
IEnumerable<Guid> ids = GetListOfGuids(); // magically get a list of GUID
Or it could maybe have been:
IList<Guid> ids = GetListOfGuids();
Let's say we want to filter on an attribute path of “|ReferenceID”. First let’s tackle the problem of converting a GUID into a string that is compatible with AFSearch. This is easy enough thanks to LINQ:
// Nicest way to convert a GUID a string compatible with AFSearch is to use GUID.ToString("B").
IEnumerable<string> idStrings = ids.Select(x => x.ToString("B"));
Okay, so now we have an enumerable collection of strings. Using what we learned in previous examples, we can knock this out:
// A little LINQ to wrap single quotes around each string item, and separate them with "; "
string delimitedIds = string.Join("; ", idStrings.Select(x => $"'{x}'"));
// An Interpolated String to substitute the items.
string query = $"|ReferenceID:IN({delimitedIds})";
Fantastic. If you prefer AFSearchTokens, that’s easy enough as well, but we do require the idStrings to generate a string array.
// Tip: here you must pass a string array, so we ToArray() on the idStrings collection. AFSearchToken token = new AFSearchToken(AFSearchFilter.Value, AFSearchOperator.In, idStrings.ToArray(), "|ReferenceID");
Granted our example would have been simplified if we defined idStrings to be an array in the first place, but what fun would there be in that?
VB.NET Examples
Some of us supporting the PI Developers Club think there should be more VB.NET examples. Towards that end, here are code snippets for the VB coders out there:
Dim uglyQuery As String = "|City:IN(London; Paris; ""San Francisco"")"
Dim prettyQuery As String = "|City:IN(London; Paris; 'San Francisco')"
Dim cities As List(Of String) = New List(Of String) From {"London", "Paris", "San Francisco"}
Cities Query Example:
Query String
' A little LINQ to wrap single quotes around each city, and separate them with "; "
Dim delimitedCities As String = String.Join("; ", cities.Select(Function(x) $"'{x}'"))
' An Interpolated String to substitute the delimitedCities.
Dim query As String = $"|City:IN({delimitedCities})"
AFSearchToken
' Tip: here you must pass a string array, so we ToArray() on the cities list. Dim token As AFSearchToken = New AFSearchToken(AFSearchFilter.Value, AFSearchOperator.In, cities.ToArray(), "|City")
Guids Example (or something that is not a collection of strings)
Query String
Dim ids As IEnumerable(Of Guid) = GetListOfGuids() ' magically get a list of GUID
' Nicest way to convert a GUID a string compatible with AFSearch is to use GUID.ToString("B").
Dim idStrings As IEnumerable(Of String) = ids.Select(Function(x) x.ToString("B"))
' A little LINQ to wrap single quotes around each string item, and separate them with "; "
Dim delimitedIds As String = String.Join("; ", idStrings.Select(Function(x) $"'{x}'"))
' An Interpolated String to substitute the items.
Dim query As String = $"|ReferenceID:IN({delimitedIds})"
AFSearchToken
' Tip: here you must pass a string array, so we ToArray() on the idStrings collection.
Dim token As AFSearchToken = New AFSearchToken(AFSearchFilter.Value, AFSearchOperator.In, idStrings.ToArray(), "|ReferenceID")
Summary
If you want to filter on a variety of values for an attribute, this requires the IN search operator.
- You may use IN in a query string or an AFSearchToken.
- Values must be exact. Therefore, IN does not work on Single or Double floating point data types.
- In query strings
- The semi-colon is the delimiter between IN values. Example: "|City:IN(London; Paris; 'San Francisco')"
- Values containing blanks must be enclosed in single or double quotes. Example: "|City:IN(London; Paris; 'San Francisco')"
- AFSearchToken
- Values must be passed as strings in an array
