Summary
When connecting legacy or new assets for IoT use cases, you are faced with a variety of options: which sensors and gateways to use, wired vs. wireless networking, battery life for sensors and gateways, which communication protocols to use, how to collect data, what functionality needs to reside at the edge (analytics, storage), device management - the choices are staggering. This session will discuss best practices for this critical first step in IoT deployments.
KEY TAKEAWAY 1: Understand the decision criteria for sensor selection as you develop your Industrial IoT strategy
KEY TAKEAWAY 2: Learn about battery life, communication protocols, and edge storage in industrial IoT use cases
KEY TAKEAWAY 3: Deepen your knowledge of Edge analytics during data collection
The following is a summary of the Hands-on Lab "IIoT Sensor Deployment - What and How" at PI World 2018 in San Francisco, CA.
All products, names, trademarks and registered trademarks are property of the respective owners. All company, product and service names used in this document are for identification purposes only. Use of these names, trademarks, and brands does not imply endorsement.
The hands-on lab covers several use cases to illustrate the various options:
- Non-invasive sensor measurements – voltage, amps, pressure, process fluid temperature, process liquid flow, liquid level, vibration, thermography (IR temperature) etc.
- Data flow via wireless communication - RF mesh network, WiFi, cellular etc.
- Data payloads via MQTT (Sparkplug B), Modbus IP, PI UFL http, OPC UA, Ethernet IP, HART-IP etc.
All examples use currently shipping or soon to be released PI System software.
The lab does not require any coding or developer related skills.
Use Case 1: Energy usage – Amps (current transformer) – Advantech
In this Exercise, you collect current (amperage) usage readings; these measurements are used to track energy consumption, unbalanced three phase loads etc.
Energy monitoring starer kit: http://www.advantech.com/products/a0af34d2-a0dd-42d9-b323-82e65581bf8f/bb-wsk-nrg-2/mod_de06dc19-f51a-441f-b23d-604777fb…
http://advantech-bb.com/product-technology/iot-and-network-edge-platforms/smartswarm-341/
Edge wireless sensor (5 year battery) uses RF mesh network to transmit to an IoT Gateway (includes support for cellular) which publishes to MQTT broker; and then is written to PI using PI Connector for MQTT (Sparkplug B)
The Smart Swarm box includes Node-RED
Use Case 2: Condition monitoring – Motor Temperature (thermal camera) – Fluke
In this Exercise, you collect temperature readings using a thermal camera.
For more information on thermography use cases, see http://www.maintworld.com/Applications/IR-Thermography-in-Maintenance
http://en-us.fluke.com/products/infrared-cameras/fluke-ti400-infrared-camera.html
Handheld thermal camera uses ad hoc WiFi to connect to a smart phone, then via cellular to transmit to Fluke Connect cloud, and then the temperature readings (no thermal images) are written to PI using PI Connector for UFL (https)
Use Case 3: Condition monitoring – Vibration - National Instruments and Allied Reliability
In this Exercise, you collect and compare vibration readings for a balanced/unbalanced motor. Condition monitoring via vibration accelerometers is widely used for CbM (condition based maintenance) and fault diagnostics.
http://www.ni.com/insightcm/http://www.ni.com/insightcm/
Interfacing with the OSIsoft PI System Software - InsightCM 3.7 Manual - National Instruments
https://alliedreliability.com/
http://www.ni.com/en-us/support/model.crio-9037.html
Vibration accelerometer (continuous ) with high sampling rate (20 kHz) is edge-processed ( including FFT - Fast Fourier Transform) to extract key features (RMS, peak, crest etc. including speficified spectral data - 1x, 2x, 20x, 47x etc.) and sent to NI InsightCM; then it is written to PI via PI Connector for OPC-UA
Reference installation: Duke Energy http://landing.ni.com/dukeenergyiiot
Use Case 4: Process fluid temperature – Emerson
In this Exercise, you collect the temperature of a process fluid flowing inside a pipe using non-intrusive pipe clamp based sensors.
https://www.emerson.com/en-us/catalog/rosemount-648-wireless-temperature-transmitter
http://www2.emersonprocess.com/siteadmincenter/pm%20rosemount%20documents/00813-0100-4952.pdf
https://www.emerson.com/en-us/catalog/emerson-1410-wireless-gateway
Wireless HART-IP device data is written to PI via PI Connector for HART-IP
Other HART-IP based devices - Emerson acoustic sensors – steam traps: Steam Traps | Emerson US
Use Case 5: Any 4-20 mA or 0-10 V sensor – Advantech
In this Exercise, you collect pressure readings. Note that the edge device (WISE 4012E) can be solar powered.
Any analog/digital sensor (4-20 mA or 0-10 V) measurement is written to PI via Modbus IP
Use Case 6: Liquid level – Keyence
In this Exercise, you collect liquid level readings. The benefits of a non-contact sensor (radar level transmitter) are detailed at:
https://www.keyence.com/products/process/level/fl/index.jsp
Other links:
PI World 2018 IoT Hands-on Lab Manual - See in the Comment section.
Fluke
https://www.fluke.com/en-us/product/condition-monitoring/vibration/3561-vibration-sensor
Corrosion monitoring
Remote non-intrusive corrosion monitoring
Monnit industrial wireless sensors
ABB wireless HART IP vibration sensor
WiMon vibration and temperature sensor | ABB
Steam traps
Monitoring Steam Traps with the PI System
Ultrasound monitoring
Bearing Condition & Lubrication Monitoring https://www.uesystems.com/product/ultra-trak-750/
FLIR thermal imaging
FLIR AX8 thermal/visual camera - w/support for Modbus/TCP and Ethernet/IP
https://www.flir.com/instruments/utilities/electric-power-generation/
Digitize and wireless enable old analog gauges
Supports BACnet and OPC
http://www.cypressenvirosystems.com/video/wireless-gauge-reader/wireless-gauge-reader-demo/
SKF vibration and oil analysis
HMS Ewon Flexy
Push Data to the OSIsoft PI System with HMS Industrial Networks
Monico mCore SDR for mobile assets (heavy trucks etc. ...)
https://www.monicoinc.com/mcore-sdr
Newer LoRaWAN Sensors and Gateways
Sensors and Gateways with built-in support for LoRaWAN is an option for situations where your plant-floor does not have WiFi/5G at all or is WiFi/5G bandwidth constrained.
Other OSIsoft links
Industrial IoT Solutions | OSIsoft
IoT Strategies and Tactics for Connecting Legacy Assets
See attached PDF below for the slides from PTC LiveWorx18 presentation
