PI AF 2018 (AF SDK 2.10) offers a very significant change in filtering on attribute values: there is no longer a restriction that the attribute must belong to an element template. The allows for a greater flexibility for filtering. For example, you may now search for attributes that don't belong to any template. Or better yet, you may search for attributes with the same name but belonging to different templates!
Other Features New to AF SDK 2.10
The bulk of this blog will cover the ValueType used with attribute value filters. Before we dig too deep into that topic, let's take a quick look at the other new features.
There is a new AFSearchFilter.ID search filter to allow searching for objects by their unique identifier (GUID). This unique ID is the fastest way to locate a given object on the AF Server. A much-welcomed addition is that the ID supports the Equal or IN( ) operator. If you are developing code, the best way to pass a GUID is by using ID.ToString("B").
New Search Fields are ConfigString, DisplayDigits, IsManualDataEntry, Trait, UOM, SecurityString, and SecurityToken. Note that with a SecurityToken field, the FindObjectFields method would return an AFSecurityRightsToken object.
PI AF 2017 R2 (AF SDK 2.9.5) introduced the AFAttributeSearch and the PlugIn filter. You could combine that filter plus the new ability to search on attributes without specifying a template. For example, you now have the ability to perform a completely server-side search of all attributes referencing the PI Point data reference! Stay tuned for a blog dedicated to this topic from one of my colleagues.
And now, the remainder of the blog will discuss the new ValueType.
If using an element or event frame Template
As mentioned earlier, previous versions required a Template for any attribute value filters. An additional requirement was that the Template needed to be specified before the attribute value filters. If the Template was specified after, then an exception was thrown.
Since AF SDK 2.10 removes the restriction on the Template, an interesting artifact is that you may specify the Template after the attribute value filter - and an exception will not be thrown. However, we strongly recommend against this practice. If you want to filter on a Template, we highly recommend you specify the Template first - just as you did with AF SDK prior to 2.10. Nothing has changed with the new version here (nor should your existing code). If you follow this advice, then you should skip the "AS valuetype" cast (more below).
Now let's consider if you don't follow the advice and you specify the Template after the attribute value filters. You will need to include the "AS valuetype" cast, and its behavior will be as described in the remainder of this document. The search will still be limited to the specified Template but as far as the attribute value filters are concerned, they will be treated as if the template was entirely omitted. Precisely how they are treated depends on the attribute's data type and the "AS valuetype" cast you declare, which is presented in detail below.
Casting AS ValueType - When not using a Template
(or the Template is specified after the attribute value filters)
To support this new capability, there are several new things to discover with AFSearch to address the issue of a filter attribute's data type. When based on a template, the data type is easily inferred. What happens if a template isn't specified and the attribute does not belong to a template and/or may span different templates? How does the search know which data type to use in the filter? The answer is that it is left up to you (the developer) to pass the desired value type as you build the search, either by a query string or search tokens:
  • New AFSearchValueType enumeration
  • A new AFSearchToken.ValueType property (a string)
  • Two new AFSearchToken constructors to allow you to indicate the ValueType (also a string)
Golden Rule:
  • If you DO specify the template, do NOT specify the value type.
  • If you do NOT specify a template, then you SHOULD specify a value type.
How carved in stone is the above "SHOULD"? If there is any possibility whatsoever of an ambiguous interpretation between a String versus a Numeric, then you absolutely should specify the value type. For example, AFSearch has no way of knowing whether 1 or '1' or "1" should be a Numeric versus a String value. Best practice: anything numeric should always specify "AS Numeric".
If you are using search tokens, you would use the new AFSearchToken constructors. If you are using a query string, you would use the new AS <value type> syntax. The available values for value type are:
  • Numeric, i.e. the literal text "Numeric"
  • String, i.e. the literal text "String"
  • EnumerationSet, the name of the applicable AFEnumerationSet. Do NOT use the literal text "EnumerationSet".
Typical Scenarios with Numeric or String
The brief examples below look very similar with the exception of the value type designator (Numeric or String). This bears repeating: you only need to use the AS valuetype if you do not specify a template.
Data Type Numeric: Integer (Byte, Int16, Int32, Int64) or Floating Point (Float, Single, or Double)
Consider if you have an attribute named RunStatus, and its data type is an Int32, where 0 means not running and 1 means running. The query string could look like either of these:
  • "|RunStatus:1 AS Numeric"
  • "|RunStatus:'1' AS Numeric"
Data Type String
And if RunStatus was a String where "0" means not running and "1" means running, you would use these:
  • "|RunStatus:1 AS String"
  • "|RunStatus:'1' AS String"
Typical Scenarios with EnumerationSet
We continue covering scenarios when you do not specify a template. We turn to another typical scenario of when the attribute's data type is an Enumeration Set. Here it doesn't matter where the data comes from, be it a PI point, a table lookup, formula, or even a static value. What matters to the value being filtered on is that the attribute has been declared to use an enumeration set. The important thing is to use the AS specifier followed by the name of the enumeration set; do NOT use the literal value "EnumerationSet".
string attrPath = "|Classification";
string attrValue = "Commercial";
string enumSetName = "Building Type";
string query = $"'{attrPath}':='{attrValue}' AS '{enumSetName}'";
The above snippet safely wraps anything I created in quotes. Note that because the enumeration set name contains a blank, I absolutely must wrap it in quotes. In this specific case where neither attrPath or attrValue contain a blank, I could have omitted the quotes. The value in the variable query will be:
"'|Classification':='Commercial' AS 'Building Type'"
Later when passed into an AFAttributeSearch constructor, the search instance will resolve to:
{|Classification:Commercial AS "Building Type"}
Cases Needing Special Consideration
There are special cases you may need to keep in mind beyond the typical Numeric, String, or EnumerationSet. Obviously an attribute that is a string should use "AS String" and an attribute that has a number data type should use "AS Numeric". What about data types that aren't so obvious? Boolean or DateTime, for example?
Data Type Boolean: cast AS String
Before we even touch on enumeration sets, let's investigate another area of caution. An attribute with a data type was Boolean is not exactly a number and not exactly a string. As far as AFSearch is concerned, you should compare the literal values of a Boolean, namely "True" and "False", as strings. Therefore the following filters would all be correct for a Boolean data type:
  • "|RunStatus:True AS String"
  • "|RunStatus:'True' AS String"
It's absolutely important with Booleans to specify "AS String". You need to be aware that the following will quietly fail by returning 0 items:
  • "|RunStatus:True"
Data Type DateTime: cast AS Numeric
This can be a bit tricky. The safest practice when dealing with DateTime attributes, whether you have a DateTime or an AFTime instance in code, is to use Round Trip Formatting. That is to say, use ToString("O") when converting a DateTime or AFTime to string for the AFSearchToken constructor or within a query string. And despite passing it as a string, it will actually be treated AS Numeric. So these snippets work:
Variable "date" can either be DateTime or AFTime instance
  • $"|Timestamp:>'{date.ToString("o")}'"
  • $"|Timestamp:>'{date.ToString("o")}' AS Numeric"
The above uses an Interpolated String. If you prefer string.Format, it would be:
  • string.Format("|Timestamp:>'{0}'", date.ToString("o"))
  • string.Format("|Timestamp:>'{0}' AS Numeric", date.ToString("o"))
TimeSpan with Data Type Anything: Not Supported
Some customers have attributes with data type "<Anything>" to hold a TimeSpan object. Value filtering on such time span attributes is not supported in AF SDK 2.10.
If your time span attribute is defined to hold an integer or a floating point, then it would be treated as a Numeric data type (see above).
Digital PIPoint with Data Type Anything (not using an AFEnumerationSet): cast AS String or Omit AS specifier
For an attribute using the PI Point data reference that grabs from a Digital tag, we recommend that the attribute data type be "<Anything>". You do not have to map the digital tag to an AFEnumerationSet. You can if you wanted to, but that means (1) you have to copy the PIStateSet as an AFEnumerationSet, and (2) what to do with the attribute falls under "AS EnumerationSet" discussed elsewhere in this document.
Assuming you have a string variable named "stateText", which contains the text of a given digital state, the following would be used to filter:
  • $"|Digital:'{stateText}'"
  • $"|Digital:'{stateText}' AS String"
For instance, if your digital tag used the "Modes" StateSet and you wanted to filter on those attributes with a mode of "Manual", either of these should suffice:
  • "|Digital:'Manual'"
  • "|Digital:'Manual' AS String"
Past AFSearch Blogs
What's new in AFSearch 2.9.5 (PI AF 2017 R2) (March 2018) - AFAttributeSearch is introduced.
Coding Tips for using the AFSearch IN Operator - you may search for multiple values using IN(value1; value2; etc.). Some code is offered to make this easier to generate.
Using the AFEventFrameSearch Class (Nov 2016) - Giving some attention to event frames since many of earliest AFSearch examples were element based.
Aggregating Event Frame Data Part 1 of 9 - Introduction (May 2017) - From the UC 2017 TechCon/DevCon hands on lab for Advanced Developers.
PI World 2018 SF Developer Track - Getting the most out of AFSearch - (May 2018) From PI World 2018, DevCon presentation for Intermediate Developers.
Why you should use the new AF SDK Search (June 2016) - The granddaddy of them all. The earliest post explaining AFSearch, which was new at that time.
