PI AF 2017 R2 (AF SDK 2.9.5) was released shortly before 2018. There are some exciting new features with AFSearch that should interest developers.
First off, I would hope any developer would always go to the Live Library What's New page for any major PI AF release. That page gives a summary of what's new with that particular release, not just for AFSearch but for all namespaces. Specific to AFSearch namespace, you would see the following:
OSIsoft.AF.Search Namespace
Two new query based search classes have been added in this release: AFAttributeSearch and AFNotificationContactTemplateSearch. The AFSearchToken.AFSearchToken(AFSearchFilter, AFSearchOperator, String, IList<AFSearchToken> ) constructor and the AFSearchToken.Tokens property have also been added to support enhanced nested query filters for searches.
The following new search tokens have been added: EventFrame, IsInternal, Parent, PlugIn, and PlugInName.
As a fellow developer and PI geek, when I first read that my reaction was "Cool! Nested queries!" If you think about it, an AFAttributeSearch means that attributes are being searched upon some element(s) or event frame(s). This implies there will first be a search for elements or event frames, followed by a search upon those results for the attributes. This does not require you to create 2 search objects on the client. Rather you will have 1 search object, namely an AFAttributeSearch, and it will have a nested query to filter on the desired elements or event frames. But the nested queries are not limited to AFAttributeSearch. For example, you may have an AFEventFrameSearch that uses a nested query for its elements.
Each release of AF SDK since 2.8.0 has introduced new features and capabilities to put more efficient searches at your fingertips. For example, if you were searching on an attribute category to return many attributes per element, you could additionally filter on PlugIn or PlugInName to restrict the returned attributes to be PI points.
Contacts Search Example
Here's a quick example where I search for any contact with a name beginning with "Davi*".
using (AFNotificationContactTemplateSearch search = new AFNotificationContactTemplateSearch(assetServer, "contact demo", " Name:'Davi*' "))
    foreach (AFNotificationContactTemplate contactTemplate in search.FindNotificationContactTemplates(fullLoad: true))
        Console.WriteLine($"   {contactTemplate.Name,-24} {contactTemplate.Contact}");
The output:
Template Contact
David Burns_Email David Burns
David Doll_OCS David Doll
David Moler_Email David Moler
Nested Queries
Let's take a look at 3 different examples that all do the exact same thing. We want to perform an attribute search for any attributes named "Feed Rate" that belong to any elements whose name starts with "Boiler". We will perform the same search 3 times, but each time how we setup the search object will be different. The 3 techniques we will briefly cover are:
  • Using Nested Search Tokens
  • Using Nested Query String
  • Using Interpolated Nested Query String
They example code is kept simple. We will perform an AFAttributeSearch searching for attributes found within a nested element query with the following filters:
  1. Attribute Category of "Process Monitoring" (note the blank)
  2. Element Category of "ProcessMonitoring" (does not have a blank)
  3. Element Template of "FCC Pump Process"
If you've ever worked with AFSearch before, then your previous experience should have been that you could not specify Category twice on a query prior to nested queries in 2.9.5
string templateName = "FCC Pump Process";
string elemCatName = "ProcessMonitoring";
string attrCatName = "Process Monitoring";
List<AFSearchToken> nestedTokens = new List<AFSearchToken>();
nestedTokens.Add(new AFSearchToken(AFSearchFilter.Template, templateName));
nestedTokens.Add(new AFSearchToken(AFSearchFilter.Category, elemCatName));
List<AFSearchToken> tokens = new List<AFSearchToken>();
// The Element uses the nested token(s)
tokens.Add(new AFSearchToken(AFSearchFilter.Element, AFSearchOperator.Equal, null, nestedTokens));
// The Attribute uses the non-nested tokens, in this case just Category.
tokens.Add(new AFSearchToken(AFSearchFilter.Category, attrCatName));
using (AFAttributeSearch search = new AFAttributeSearch(root.Database, "nested tokens example", tokens))
    search.CacheTimeout = TimeSpan.FromMinutes(10);
    foreach (AFAttribute item in search.FindAttributes())
        // Do something
The trick with a nested query string is that it will be enclosed in {braces}.
// Notice how element has nested { }.
// The Category depends on nesting level. 'Process Monitoring' with a blank is outside the nesting,
// so it will be an Attribute Category, whereas 'ProcessMonitoring' inside the nesting is an
// Element Category.
string query = "Element:{Template:'FCC Pump Process' Category:'ProcessMonitoring'} Category:'Process Monitoring'";
using (AFAttributeSearch search = new AFAttributeSearch(root.Database, "nested query string", query))
        // Do Something
Using Interpolated Nested Query Strings
With Interpolated Strings, you may easily substitute a variable's value (technically, it substitute's the string returned from the variable's ToString() method). If you are familiar with this in either C# or VB.NET, you know that {braces} are used. This raises an interesting question of how the Interpolated String knows which brace is for the nested query, and which is for the value substitution. You would denote that using an escape sequence of the braces themselves.
// This gives a compile error with an Interpolated String
// string query = $"Element:{Template:'{templateName}' Category:'{elemCatName}'} Category:'{attrCatName}'";
// Escape the { and } around literal braces with {{ and }}.
// Fun Fact: {{something}} is called the Mustache Template!
// See https://en.wikipedia.org/wiki/Mustache_(template_system)
string query = $"Element:{{Template:'{templateName}' Category:'{elemCatName}'}} Category:'{attrCatName}'";
using (AFAttributeSearch search = new AFAttributeSearch(root.Database, "interpolated nested query string", query))
        // Do Something
An interesting bit of trivia: the {{something}} format of double braces is called the Mustache Template!
AFAttributeSearch
The nested query examples used AFAttributeSearch for searching upon elements. The AFAttributeSearch may search on event frames instead.
One thing to note is the fullLoad parameter is missing from the FindAttributes method because it must always do a full load since the attributes cannot exist without the owning element or event frame. However, the AFAttributeSearch.FindObjectFields is smart enough to know when it must make a full load to evaluate data references. To state that a different way, it is smart enough to know when to skip a full load because of captured event frames. You don't have to do anything special like consult Oracles to figure this out for any given situation. You would code it the same way regardless of the situation and let AFAttributeSearch.FindObjectFields make the right decision!
Why you should use the new search classes
Maintainability - some Find methods in AFAttribute or AFNotificationContactTemplate have already been marked as Obsolete, and it is reasonable to suspect that others may be marked so with future releases of AF SDK. Make your applications more resilient by switching to these new methods sooner rather than later.
Performance - if you require fetching more than one page of results from the server and you opt-in to server-side caching, any of the AFSearch classes perform much faster than the older methods. This means that AFAttributeSearch will be much faster than the AFAttribute.FindElementAttributes overloads.
Ease of Use - the AFSearch classes take care of paging issues seamlessly for you. The new nested queries makes searching for attributes on either elements or event frames very easy with fewer lines of code. There is previously mentioned smartness built into AFAttributeSearch.FindObjectFields. All of this without extra coding on your part.
Reliability - when searching on attribute values that might be evaluated client-side (due to needing to evaluate the data reference), it is impossible to do paging properly using the older search methods because you don’t reliably know what to use for the next page index. By opting-in to server-side caching with the newer AFSearch methods, paging is more reliable.
