Is it possible to configure schedules in the Adapter for OPC UA?
I have not found if it's possible to set the schedule of scanning from a data source configured in the adapter of opc ua in the documentation, but when I try it to use the edgecmd to set the schedule I get that the 'schedules' facet is not found. If I use 'schedule' the same thing happens. I am following the EdgeCmd commands (aveva.com) documents also for reference.
I assumed the schedule was configurable based on how the EdgeCmd utility documentation was written. What command would I have to use to make this work?
Also, if it's not possible to configure schedules, what is the default scan rate of the adapter from the configured data source?
