Reading several PI points in once call.
I need to read serveral PI points values at one call. I need to read the values for certain tags only and not all the points. However, I keep on getting an exceptioon that 'tag' attriubte is duplicated.
Below is the code I'm using.
    Dim myPIserver As PIServer = Nothing
    Dim startTime As String = ""
    Dim endTime As String = ""
    Dim fltrExp As String = ""
    Dim filtered As Boolean = True
    'connection to PI server
    If myPIserver Is Nothing Then
      myPIserver = New PIServers().DefaultPIServer
    End If
    'Query for PI Point
    Dim tagMasks() As String = {"tag1", "tag2", "tag3"}
    Dim ptQuery As New List(Of PIPointQuery)()
    Dim tags = ""
    For Each item As String In tagMasks
      ptQuery.Add(New PIPointQuery(attributeName:=PICommonPointAttributes.Tag, AFSearchOperator.Equal, item))
    Next
    ' Dim myPointList As New PIPointList(OSIsoft.AF.PI.PIPoint.FindPIPoints(myPIserver, ptQuery))
    Dim myPointList As New PIPointList(PIPoint.FindPIPoints(myPIserver, ptQuery))
    startTime = "*-7d"
    endTime = "*"
    'Retrieve events using PIPointList.RecordedValues into list 'myAFvalues'
    Dim myAFvalues As List(Of AFValues) = myPointList.RecordedValues(New AFTimeRange(startTime, endTime), AFBoundaryType.Inside, "", filtered, New PIPagingConfiguration(PIPageType.EventCount, 10000)).ToList()
