analysis that writes multiple OutPutTimes in one TriggerTime
good day,
I am looking for the best way to do multiple calculations at the same time for different OutputTime. Some way to do BackFill.
Could you advise me on the best way to achieve this?
the best way is to give an example:
At 0:00 clock calculate 24 hourly averages and write them in times for the last 24 hours.
Trigger Time Output Time Variable1 InputValue
06.12.2023 0:00:00 05.12.2023 21:00:00 1.3548E+08 135478160
06.12.2023 0:00:00 05.12.2023 22:00:00 1.3548E+08 135482304
06.12.2023 0:00:00 05.12.2023 23:00:00 1.3549E+08 135486160
06/12/2023 0:00:00 06/12/2023 0:00:00 1.3549E+08 135489760
Thank you in advance
  • Hello!
    To achieve this you'll have to create 24 different analyses, triggered at midnight. Then, in the triggering section, click the Advanced button and set the Output Time for each of them correctly. You could use the 'relative to triggering time' option, and specify *-1h, *-2h, etc. or just point them to an AF Attribute, containing the different output timestamps.
