Connecting to a PIServer with a domain user
I'm trying to use the AF SDK to connect to a PI Server like this (simplified):
PIServers piServers = new PIServers();
_server = piServers[serverName];
string domain = mydomain;
string username = myusername;
string password = mypassword;
NetworkCredential netCred = new NetworkCredential(username, password, domain);
_server.Connect(netCred);
I've mapped the user to the piadmins Identity on the PI Server, but when I try to connect, I get an exception with the message "Cannot connect to the PI Data Archive."
In the PI Message Logs I get the following message: "Unsuccessful login  ID: 105. Address: 172.19.30.185. Name: God.Tag.Server.Console.vshost.exe(1748):remote. Credentials used: petter.brodin. Method: Explicit Login. Error: [-12001] Name Not Found in PInt"
Is there any reason why this shouldn't work? Is there a better way to approach this when attempting to log in with a domain user?
Parents
  • This thread gives some good examples:
    Re: AFSDK: How to connect to a PI system across domains thru AFSDK C#?
    But that's what you already did. Did you setup the connection preferences correctly in PISDK settings? There are typically more messages in the log for the connection entry, What are the others? Are you trying to connect using the Petter Brodin credential, or is that your current user credential?
  • I decompiled the AF SDK DLL, and it looks like the Domain property of the NetworkCredential is never used. Instead, it just does an explicit login with username and password.
  • Hi and thanks for the reply.
    First of all, apologies for decompiling the code. I got a bit overeager and forgot to check if it went against the Terms&Services. It won't happen again!
    Thanks for the explanation as well, it makes sense. Just to make sure: are you saying it should be possible to connect with credentials as a user on a different domain? We often deploy our software to client networks where we don't have full control of the network, so I can imagine (though based on what you say I hope we don't end up in) a situation where we'll be have to specify domain, username and password through a NetworkCredentials object.
Reply
Children
No Data
