Hi Guys.
I would like to inquire about the issue mentioned in the PI Web API Admin Event Logs.
[Configuration]: Failed to connect to the remote configuration repository. Retrying every 15 seconds. Exception:
System.ServiceModel.CommunicationException: Cannot connect to server 'PermianBasin'. ---> System.ServiceModel.EndpointNotFoundException: Could not connect to net.tcp://pbctcemhist:5457/AFServer/Service. The connection attempt lasted for a time span of 00:00:04.0403139. TCP error code 10061: No connection could be made because the target machine actively refused it 100.116.7.25:5457. ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 100.116.7.25:5457
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at System.ServiceModel.Channels.SocketConnectionInitiator.Connect(Uri uri, TimeSpan timeout)
--- End of inner exception stack trace ---
I applied the updated 'PI-Web-API-2023-SP1-Patch-1_1.19.1.28_' patch. After the patch, I encountered the error above in the event logs. However, when checking the connections to DA, AF, Vision, and accessing the PI Web API, everything seems to be functioning properly. The IP address indicated as '100.xx.7.xx' is not a AF Server and I believe I need to remove it, but I cannot locate where to check this. Perhaps someone here knows how to address this error?
Thanks
roy
