Good day,
Is it possible, via a PI Adapter interface to a Honeywell PHD server, to import data into an OSI PI Historian for a period prior to the PI Point’s creation date in OSI PI?
Kind regards
Bala Moodley
Good day,
Kind regards
Bala Moodley
Is the honeywell PHD server exposed using OPC UA? If so, you likely can use a PI Adapter/PI Connector. If it is using OPC HDA, use the PI OPC HDA interface. Yes, the PI System can create store values prior to the point creation data as long as you have archive created and online for the date range to store.
