Collective creation, how to establish a different name between the collective and Primary Server
Hi:
I am configuring a new Collective, I have my primary and secondary servers (Example names: Serv1 and Serv2) and I need my collective to be named differently from the primary and secondary (Example: ServCollective). When I am running my wizard it asks if the pi server is new or existing. When I select that it is a new server it allows me to put a different name under the collective, because if I select existing it automatically sets the collective name as the primary server name. When I continue the wizard it changes in the sdk the name of the primary (Serv1) to (ServCollective)), and then my connection goes crazy since the names dont match. What am I doing wrong?
I do have an error before finishing the wizard, regarding some backup policies (I think, since it always stops in that part) that dont let me finish it. But I dont know if the renaming issue is somehow related to this error. Basically I cant finish the wizard and I cancel it, but anyhow, the renaming still happens and I dont know if I can even name the collective differently from the primary at all. Should the Collective has to have the same name as the Primary no matter what?
I'll appreciate any guidance if some of you know about this issue.
Thanks
ZG
