Is it possible to connect a remote OPC UA/SQL server to a PI System in the cloud without Edge?
Let's say that I have an OPC UA and SQL server on premise which have internet access. My PI System is in my own cloud environment where the AF and DA are in 1 VM, SQL and Web API are in another VM.
1) Is it possible to connect my OPC UA and SQL servers to my PI AF/DA machine in the cloud?
2) If so, is it okay to install the PI Adapter for OPC UA and PI Adapter for RDBMS on my PI AF/DA machine to retrieve data from my OPC UA and SQL servers (instead of installing them on the OPC UA/SQL servers)?
3) Is PI Web API required then? Or is it okay to set egress of the PI Adapter to the port in which the PI DA is installed in.
Any information on this is appreciated, thank you!
