Manually split an event frame
I am working with event frames to track the reasons of batch process delay. The event table in the attached screenshot is built on PI Vision display to allow the users to select the reason code from the dropdown box for each event. However, sometimes there are more than one delay reason for each event. The user requirement is to have the feature to split the event manually whenever it is necessary. And the event breaking time should be entered manually at PI Vision display by the user. Could you advise how to achieve this? Thanks in advance.
