PI AF Analyses for Pump On/Off (Pump Cycling)
I want to create a PI tag that counts how many times we are cycling our pumps at a daily and monthly interval, using Analyses.
The criteria for a "pump cycle", is it has zero flowrate and pump status = 'Off' for 3 minutes or longer. Attached is a picture of the current logic I created in PI AF.
However, the Analyses is not working as I expected, and I am getting really high values (hundreds of daily pump cycles, thousands of monthly pump cycles). I think it is likely because there is no stop trigger once the "pump cycle" condition has been met. Therefore, if a pump is off for an hour, it will count this as many pump cycles instead of one, since it meets the zero flowrate and pump status = 'Off' condition for the entire duration.
Does anyone have experience with creating a tag for a scenario like this? Or has suggestions on how to fix the logic.
Thanks
  • Hi
    Some pointers for you:
    1. In your CycleDetected expression you output to a PI Point attribute. To avoid confusion, this should be a separate analysis. I see you are differentiating between checking the analysis variable CycleDetected and the AF Attribute 'Cycle Detected' but in general, it's better to have it separate and always use the AF Attribute.
    2. I see you are attempting to assign values to CycleCount inside the CycleCounter expression. I don't believe this works, but if it does, it's not recommended. It's only the output attribute 'Cycle Counter' that should receive values from the CycleCounter expression
    3. In the Daily and Monthly counters you're uing the EventCount function, but this counts all events written to a tag - regardless of value. If you want to continue using this function, you need to make sure you count the right thing. See below!
    To use EventCount, you need to make sure you only output one of the conditions to your conditional expressions before. I'm not going into your actual business logic here, but once you have ensured you have a validated cycle, you should only output the 1's - not the 0's. Call it an event indicator, and output that to a PI Point attribute. Then you can count daily and monthly events using the EventCount function.
  • Hi Asle,
    Thanks for your response. I have made those changes but am still getting incorrect values, and my analysis isn't set up properly. I have the following separate analysis:
    PumpOff
    // Check if flowrate is 0 and pump status is 'Off' for last 3 minutes
    If TimeLE('Flowrate', '*-3m', '*', 0.1) = 180 And TimeEq('Pump Status','*-3m', '*', 0) = 180
    Then 1 // If 'Yes', then pump is off, trigger cycle, set to 1
    Else 0 // If 'No', then pump is on, set to 0
    CycleTrigger
    // Check if pump is currently 'Off' and previous value value was 'On' - indicates a cycle
    If TagVal('Pump Off','*') = 1 And PrevVal('Pump Off', '*') = 0
    Then 1 // If 'Yes', trigger, set to 1
    Else 0// If 'No', set to 0
    CycleCountDaily
    // Totalize no. of times the CycleTrigger tag was equal to 1 since midnight
    EventCount('Cycle Trigger','t','*')
    CycleCountMonthly
    // Totalize no. of times the CycleTrigger tag was equal to 1 since midnight at start of the month
    EventCount('Cycle Trigger', BOM('*'), '*')
    I'm wondering which of these analysis should be Periodic and which should be Event-Triggered, and at what interval if periodic. How do I get the EventCount function to only count the 1's and not the 0's? Alternatively, should I be using a "counter" to count how many times a cycle has been triggered and utilizing the TagTot function instead?
    I believe I have the PumpOff and CycleTrigger functions working as expected, it's just a matter of being able to count how many times at a daily and monthly interval that CycleTrigger = 0. What is the best approach for this?
  • Hi Asle,
    I was able to get the analysis working as I expected using the following analysis:
    CycleCountDaily
    CycleCountMonthly
    CycleTrigger
    If 'Pump Off' = 1 And PrevVal('Pump Off', '*') = 0
    Else NoOutput() // If 'No', set to 0
    PumpOff
    If TimeLE('Flowrate', '*-10s', '*', 1) = 10 And TimeEq('Pump Status','*-10s', '*', 0) = 10
    I'm fairly certain that in the CycleTrigger analysis, having 'Else 0' instead of 'Else NoOutput()" was messing with the EventCount formula. Whereas now, with the NoOutput() function it is working as expected.
    Thanks for your help/
  • Here's what I'd suggest trying:
    PumpOff
    <No changes>
    CycleTrigger
    Change: Don't use TagVal('Pump Off','*') as this function interpolates values (unless you intend to have values interpolated). It might not mean much right now, but once you get into recalculating the analysis later, it could mean trouble. Just refer to the attribute in single quotes to get the current value.
    CycleCountDaily
    TagTot('Cycle Trigger', 't', '*', "", 100, "EventWeighted")
    Change: Use TagTot instead of EventCount, but make sure you put "EventWeighted" in the last parameter. The fifth parameter is PercentGood, so please specify the lowest percentage good values you can accept and still rely on the calculated number being correct.
    CycleCountMonthly
    TagTot('Cycle Trigger', BOM('*'), '*', "", 100, "EventWeighted")
    Change: TagTot instead of EventCount
  • Yes, it was most certainly counting the 0's in addition to the 1's.
