How to export "created by" for AF elements?
I am not able to find the complete version information for the AF elements
i.e. I can find and export in PI builder:
 VersionCreationDate
VersionModifyDate
VersionModifier
CreationDate
but not who initially created the element.
I can see this information in PSE but I would like to find this information in an export without using the AF audit trail tool
any suggestions?
  • Hi ​,
    To export the "created by" information for AF elements in PI System, unfortunately, PI Builder does not provide a direct option to export who initially created the element. However, there are a few alternative methods you can try:
    1.Using PI System Explorer (PSE):
    • You can view the "created by" information in PSE, but it cannot be directly exported. You might need to manually note this information if only a few elements need checking.
    2.Using XML Export:
    • You can export AF elements to an XML file using PSE. Although this does not explicitly show "created by," you can get a lot of detailed information about the elements.
    Thanks
