Hi, i am trying to query from PIOLED Enterprise, when not specifying the path details, its able to show the results
but when specifying the path its return empty result
any idea what goes wrong? it is due to installation of PI SQL DAS RTQP?
Hello Hezleen ,
You must not consider the AFDatabase name in the path. Please try "WHERE eh.Path = N'\TEST\'.
When you run into a problem like this with the WHERE condition obviously containing something wrong, it helps to look to just the table which has the WHERE condition column.
Just execute a query against PIFD.Asset.ElementHierarchy and see what the data in column 'Path' looks like. Something like the following comes in pretty handy:
SELECT distinct Path FROM [PIFD].[Asset].[ElementHierarchy]
Hi Gregor,
Thank you very much for your help.. able to query successfully..
