I have two pi server,can i set one web api connect both it?
Hi xiaodong ,
Yes, 1-N connection is supported by PI Web API. Just add your Data or Asset servers from PI Web API node using PI System Explorer.
In order to read, write data, your enduser and service account may need permissions.
Thank you very much, is it also okay to two HA?
Yes, you should expose the PI Web API through a load balancer for production workloads (via 2 or more servers depending on use-case).
