Hello,
I have a problem with Toolbars in PI ProcessBook, like the image, I never saw the error.
When I open a pdi. the toolbars disapear, also the names are incorrect, "true" are not the names.
Thanks in advance.
Hello,
Thanks in advance.
ProcessBook is a deprecated product and you should work to deploy new visuals to PI Vision, or migrate existing displays to Vision as well. PI Vision 2023 SP1 (aveva.com)
Thanks MainelyInnovations for your answer, I just want to migrate those Processook displays but the problem apears. Now I can't change the AF and DA connections. Some suggestions in order to solve the problem.
Thanks in advance.
Hi IRabanal ,
Please try following this article to see if it resolves your issue.
PI ProcessBook Default Menu Bar disappears and if it is reenabled then it quickly disappears again
Hi Jinmo,
Thanks for your answer, It works. In adiction you can build the toolbars just addin from Commands but whit diferent name. If someone needs it.
Thanks the problem was resolved.
