I am using CurrentValues() method to read real time data of pipoints.
I am receiving some Data with old timestamp despite the presence of data with timestamp newer.
Is there any other method to read current data with the latest timestamp ?
Hi
Which technology are you using here?
I'm not sure there's a CurrentValues() method anywhere, but I find a CurrentValue() method in the PIPoint namespace of the AF SDK.
And are you reading values directly from a PI Point (from PI Data Archive) or is the PI Point mapped to an AF Attribute?
I am using OSIsoft.AFSDK version 4.0.0.0,
Here's the code snippet to fetch the current value of a list of PI points:
AFListResults<PIPoint, AFValue> values = pointList.CurrentValue();
I'm directly retrieving values from PI points, without any mapping to AF attributes.
The issue I'm encountering is that I'm getting a value from a PI point with a timestamp that isn't the most recent.
Here's the problem at hand: I'm utilizing a sample client to input data via the UpdateValue method, with the timestamp set to the current time. I aim to archive older data, specifically entries older than 5 days, by inserting them with their respective historical timestamps. However, upon inserting data with the sample client and attempting to retrieve the current value using another sample client, I've observed that I'm retrieving old data with outdated timestamps instead of the most recent data. The CurrentValue function should ideally return the latest data with the most recent timestamp, not the recently inserted data with an older timestamp.
All right. I see a couple of potential issues here:
This seems a bit strange, everything should be collected based on the timestamp of the value - not by the order they were inserted in.
Can you please try the RecordedValue() instead? It has parameters to specify timestamp and retrieval mode, so you have a bit more control of what you request / get.
