How to properly setup digital tags in database?
I'm new to Pi and would like to know if anyone can help figure out tag setup for a particular type of PLC. I have an Automation Direct PLC that doesn't pair with the Pi system very well. Mostly all the pointtype's are Int16 or Float 32. This is fine for those values in the PLC, but digital values either say BAD, Under Range or Configure. If they match the typical value, they record data. This format works for our AB PLC's but not this type for some reason.
I don't know who set them up, but I am trying to fix them. It seems like the digital format doesn't want to work and I can use some help/explanation.
Thanks
