I have a signal give flow (kg/min) and I need kg.
Hi lmc8_9 ,
One way is to use the TagTot function. Because this function assumes the rate tag to be XXX/day, you will need to multiply the end result by 24*60 (1440 Minutes in a day).
Thank you so much!
