Hi NitinRajput
you can use INT('time range') to convert a timestamp to a number.
for example, Int((Bom('*')-Bom('*-1mo')))
the UOM of the result is seconds.
divide by 3600 to convert the UOM to hours:
Int((Bom('*')-Bom('*-1mo')))/3600
Best Regards
Runpu
I was always disappointed that then-OSIsoft did not make their own Asset Analytics UOM-aware. I often stated that (timestamp2 - timestamp1) should not return a scalar number, but rather should return a number with a UOM of seconds. Instead it is left to each person to do this on their own.
That said, I would suggest using:
Expression: Convert(Variable2 - Variable1, "s")
Expression: Convert(DeltaSeconds, "h")
The first convert really does not convert but simply assigns a UOM.
