Deleting buffer content of PI connection relay and/or PI OPC UA connector
Hi all,
how can I delete or reset a buffer content, because there is a lot of data in it with PI points
that are already removed in PIDA server.
Thanks.
Edi
  • Check for LocalBufferPath attribute in config file
    %pihome64%\Connectors\OPCUA\OPCUA.ConnectorHost.exe.config
    Connector to Relay Buffering Default Path --> ProgramData\OSIsoft\Tau\OPCUA.ConnectorHost\OPCUA\Buffer\amqprelay_#IPaddress\
    Relay to PI System buffering Default Path --> ProgramData\OSIsoft\Tau\Relay.ConnectorHost\PI Connector Relay\Buffer\PI_#DataArchiveName\
    Move the buffer folder and files, restart PI System connector. You may lose the data for valid points and above procedure is valid for corrupted buffer in connectors.
  • Thank you for your advice.
    Unfortunately it doesn't fix the problem which now results in "maximum license point count exceeded".
    But that's not true because I removed unwanted PI points in PIDA so that MaxPointCount is below licensed maximum.
    I opened a case at Osisoft.
