AWS RDS Custom for SQL
Hi all,
While PI AF / PI Vision are not supported on AWS RDS, AWS RDS custom does appear to provide some of the missing features that blocked implementation before.
Does anyone have some ideas about that?
https://aws.amazon.com/rds/custom/
  • Hi Roger!
    I know this is a super old thread, but yes, it definitely works. It came up in my search as I worked with other customers that were implementing this, now that I moved on the AWS side Slight smile Although, I would check with the respective teams (PI Vision, AF) if they have limitations around supporting it, but from a technical standpoint, it does work and allows you access to the OS level so you can create the local groups, run the scripts locally, etc.
