I am trying to use the Value Retrieval Method 'Total' in an event frame template but continue to run into the error "The TimeRangeMethod 'Total' cannot be combined with Time support. UOM could be different."
I believe if I use any other time mode it will not capture the Start and End time of the Event Frame. I know I can instead use an Output Expression in the Event Frame Generation Analysis, but was hoping to use the simpler PI Point Data Reference instead. Any thoughts?
