PI Vision showing wrong value only in present time after recalculating
This is a problem I run into pretty often and I still don't know what causes it. I have a tag I want to display in PI Vision, but sometimes after recalculating the analysis, even if the attribute shows the correct value, PI Vision shows a value of a previous timestamp. Sometimes this previous value, doesn't even exist anymore when I look for it in the Archive Editor so I don't understand where it comes from. The curious thing is that seems the analysis works well because if I go back any amount of time in PI Vision (e.g. 1 min in the past), it shows the correct value. It's like the correct values are "following" the present, but there's a wrong value stuck in the present all the time.
Thanks.
