I have a template called "CHAMPION ARENA_North" and all of my PI tag attribute reference the PI Server name via an attribute called "PIHistorianSource". The PIHistorianSource attribute is being referenced from within the SAME template. Where PIHistorianSource = "PRODPISERVER1" (The name of the PI Historian)
My working element attribute relative path look like this
Element Attribute Relative Path: \\%@PIHistorianSource%\%..\..\ElementDescription%_%Element% - %Attribute%
Result: \\PRODPISERVER1\District12\HungerGames_Tornament - Attendees
We've decided to point this templates list of PI Tag attributes reference as well as many other templates containing PI tag attributes to reference "PIHistorianInput" from a different element called "SYSTEM" instead. This will allow us to change the PI Historian server from a single point of reference for testing purposes.
However, I am having challenges applying a functional remap to "PIHistorianInput" string attribute within the SYSTEM element. I have applied he following references with no success
\\%SYSTEM|@PIHistorianInput%\%..\..\ElementDescription%_%Element% - %Attribute%
\\%@SYSTEM|PIHistorianInput%\%..\..\ElementDescription%_%Element% - %Attribute%
\\%SYSTEM|PIHistorianInput%\%..\..\ElementDescription%_%Element% - %Attribute%
\\SYSTEM|PIHistorianInput%\%..\..\ElementDescription%_%Element% - %Attribute%
Any ideas as to how to map the element attribute relative path to achieve the same result?
