How should I call an attribute within an expression function?
I am building a template that will be using a certain value many times throughout the various expressions. For example under an expression analysis:
IF TagMax('A','*-100m','*') = 1 then 1 ELSE 0
How can I edit the syntax of this formula to make the number 100 as an attribute and call it within the expression? It will be the equivalent of the following:
[x] = 100 as an attribute
IF TagMax('A','*-[x]m','*') = 1 then 1 ELSE 0
