Delete values using PowerShell
Hello,
We need to delete particular values appearing at 00:00:01 every day for a tag. Rest of the values must remain. We created attached PowerShell script to achieve the same, but getting a prompt for 'Connection:' while executing.
cmdlet Get-PIPoint at command pipeline position 1
Supply values for the following parameters:
(Type !? for Help.)
Connection:
Could you please suggest what do we need to enter against this prompt? Or could there be some other issue?
Thanks,
Sujoy Halder
PowerShell code:
# Load the OSIsoft PowerShell Extensions
Import-Module OSIsoft.PowerShell
# Connect to the PI Data Archive by specifying its name
$piDataArchiveName = "PI-Global"
Connect-PIDataArchive -PIDataArchiveMachineName $piDataArchiveName
# Define the start and end dates
$startDate = Get-Date "10 June 2024 00:00:01"
$endDate = Get-Date "11 June 2024 00:00:01"
# Define the tag name
$tagName = 'ESUM_NV_all_Vorhersage_1D'
# Retrieve the PIPoint object for the tag name
$piPoint = Get-PIPoint -Name $tagName
# Loop through each day in the range and remove the value at 00:00:01
while ($startDate -le $endDate) {
    # Define the specific time for the value to be deleted
    $specificTime = $startDate.Date.AddSeconds(1) # This ensures the time is 00:00:01
    # Get the PI value for the tag at the specified timestamp using the PIPoint object
    $piValue = Get-PIValue -PIPoint $piPoint -Time $specificTime
    # Check if the value exists before attempting to remove it
    if ($piValue -ne $null) {
        # Remove the PI value
        Remove-PIValue -PIValue $piValue
        Write-Host "Deleted value for $tagName on $($specificTime)"
    else {
        Write-Host "No value found for $tagName on $($specificTime)"
    # Move to the next day
    $startDate = $startDate.AddDays(1)
Write-Host "Completed deletion of values for the specified date range."
  • GetPIValue Class (aveva.com)
    RemovePIValue Class (aveva.com)
    You need to specify the connection. Review the examples on the documentation.
    $con = Connect-PIDataArchive -PIDataArchiveMachineName $piDataArchiveName
    $piPoint = Get-PIPoint -Name $tagName -Connection $con
    foreach ... {
      $piValue = Get-PIValue -PIPoint $piPoint -Time $specificTime -Connection $con
      Remove-PIValue -PIValue $piValue -Connection $con
  • Thanks for your answer. I was able to make it work.
    # Connect to the PI Data Archive and store the connection in a variable
    $piConnection = Connect-PIDataArchive -PIDataArchiveMachineName $piDataArchiveName
    # Use the stored connection for the Get-PIPoint cmdlet
    $endDate = Get-Date "15 February 2025 00:00:01"
    $piPoint = Get-PIPoint -Name $tagName -Connection $piConnection
        # Remove the PI value using the PIPoint object and the specific time
        Remove-PIValue -PIPoint $piPoint -Time $specificTime
    else {
