goode Without a lot of detail to work with I would first make sure the pi server is running. Go to your command prompt and try this first:
cd /d %piserver%\adm
PISRVSTART
If your pi server is running, I would next work to confirm you have the authority to create a pi archive - pedestrians using the pi server do not have admin rights to add, edit, register or unregister archives. BUT if you know you have the authority, I would run the following commands from your command prompt:
piartool -ac {{ your archive directory and archive name here }}
This will create and register a new archive. You do not need the PI System Managment Tools (PI SMT) utility to create and register an archive. Now if that works you should see the new archive in the list of archives in PI SMT. If that worked you should also be able to register the archive you "lost" if the archive is in the directory you used in the command line above simply register it by typing from the same prompt location:
piartool -ar {{ your archive directory and "lost" archive name here }}
For example: piartool -ar E:\PI\arc\HST2_2025-08-08_16-38-22.arc
From the screenshot, I can see you’re logged in as piadmin, so this is not a permissions issue. The problem is most likely due to an unregistered archive. You have two options:
This will configure a new primary archive so that PI can start tracking data again.
