Hi.
I have a UFL instance which is handling data from several different sources (same point source). It is a very simple input file which on contains the bare minimum of tag,timestamp,value.
However, now I need to also handle string values. Is it possible to do this within the same UFL instance? If so, how do I do it? Right now, I only have these three fields defined and one action of storing the three fields to PI.
