OPC Client.exe missing after installing OPCint_ReadOnly and PIICU_1.5.1.10 on new Pi Node
Hello Everyone,
I am taking over Pi as Admin since the IT PI Admins team is not longer with the company. I am trying to setup a new Pi Node on a VM running KepServerEX V6. I installed both files OPCint_ReadOnly and PIICU_1.5.1.10 and at this point I am just looking at checking to see if the Pi OPC Client can see the tags in the Kepware Server on the same host machine, however the PI OPC Client tool is not showing under PI System or in the folder PIPC. The OPC Client doesn't seem to be available as a separate install file from the customer portal. Any insight would be highly appreciated. Thank you.
