Hello,
We're trying to use the NoReplace option when sending batch and it doesn't work. For a single timeseries it does work. For example, the following URL, does work from postman:
https://piserver/piwebapi/streams/F1DPUpybrj1AHkOSeTdNPi93FAI7cAAARURNUElEMVxLQ0hfUEhfR0VOX01XXzQwLk9WRVJSSURF/recorded?UpdateOption=NoReplace
But, when we try to send a batch, the NoReplace is ignored:
"0":
"Method":"POST",
"Resource":https://piserver/piwebapi/streams/F1DPUpybrj1AHkOSeTdNPi93FAI7cAAARURNUElEMVxLQ0hfUEhfR0VOX01XXzQwLk9WRVJSSURF/recorded?UpdateOption=NoReplace,
"Content":"[
{\u0022Timestamp\u0022:\u00222025-06-10T12:00:00.0000000\u0022,
\u0022Good\u0022:true,
\u0022Questionable\u0022:false,
\u0022Value\u0022:\u002225\u0022
The code that create the batch is:
var batchRequest = new Dictionary<string, BatchSubRequest>(); foreach (var item in requestModel.Select((Item, Index) => new { Item, Index })) { if (item.Item.Errors != null && item.Item.Errors?.Count > 0) continue; string url = baseUrl + $"streams/{item.Item.WebId}/recorded?UpdateOption={updateOption}"; var request = new BatchSubRequest() { Method = "POST", Resource = url, Content = JsonSerializer.Serialize(item.Item.Items, new JsonSerializerOptions { DefaultIgnoreCondition = JsonIgnoreCondition.WhenWritingNull, PropertyNameCaseInsensitive = true }) }; batchRequest.Add(item.Index.ToString(), request); } var batchResp = await BatchRequest(new BatchRequestModel() { Requests = batchRequest }); … internal async Task<IDictionary<int, BatchSubResponse>> BatchRequest(BatchRequestModel requestModel) { try { var client = _httpClientFactory.CreateClient(); string url = baseUrl + @"batch"; var requestData = JsonSerializer.Serialize(requestModel.Requests, new JsonSerializerOptions { DefaultIgnoreCondition = JsonIgnoreCondition.WhenWritingNull, PropertyNameCaseInsensitive = true }); HttpRequestMessage httpRequest = new HttpRequestMessage(HttpMethod.Post, url); httpRequest.Content = new StringContent(requestData, Encoding.UTF8, "application/json"); HttpResponseMessage httpResponse = await client.SendAsync(httpRequest); httpResponse.EnsureSuccessStatusCode(); string response = await httpResponse.Content.ReadAsStringAsync();
Thank you,
Ken
